Object Snap Control "alt+click" Mac Equivalent?
Hello!
I’m doing the headphones tutorial in the User Guide and throughout the guide I’ve run into this function where you can “alt+click” on an Osnap option and it’ll enable just that, disabling the rest. I thought “option+click” would be the mac equivalent, but it doesn’t seem to work. I’ve tried some other combos of option, command, shift, etc to no avail.
Is there an existing hotkey, or would I have to create a custom one?
Thanks!
on the mac it’s option click to enable one and disable the others,
but I’m thinking you are looking for the “one shot” radio button instead
I for one find that whole thing frustrating and run all snaps enabled persistent, with the disable all button checked until I need them.
I then turn them on as needed by holding down option to temporarily enable them releasing option to return to a no osnap state.
Hm, I must have accidentally messed with the settings somewhere, because the option click doesn’t work for me.
Normally it’s a simple right-click on the desired osnap (in Windows Rhino anyway).
