hi Everyone,
i think there is an issue with the explodeblock command on linked blocks
- insert a block instance (options: linked to file, layer style active)
- select the block
- run ExplodeBlock command
The object layers of the objects inside the block are lost (e.g set to ‘0’. Expected behavior is that the layers remain unchanged.
testblock.3dm (37.7 KB)
