Hi all,
within a plugin I was trying to explode linked block to use its components.
It all works fine with single standard blocks. But nested linked problems causes some problems.
As an example:
file A and file B are inserted in file C as linked blocks.
When using C as linked block in file D and exploding this block the result is obviously having linked blocks A and B in D. Unfortunately there is always ONE of these resulting blocks that is document controlled and can not be moved, deleted or edited in whatever way. It stays there where it is. Only by closing and opening the file this block will gone…
Code snippet (within a command):
ObjRef objRef = RS.RNGet.GetObject("get block", ObjectType.InstanceReference);
ObjRef[] objRefs;
Rhino.Input.Custom.GetObject go;
go = new Rhino.Input.Custom.GetObject();
go.SetCommandPrompt("get instance object");
go.GeometryFilter = ObjectType.InstanceReference;
go.SubObjectSelect = false;
go.AcceptNothing(true);
//go.GetMultiple(1,0);
go.Get();
if (go.CommandResult() != Rhino.Commands.Result.Success)
return Result.Cancel;
objRef = go.Object(0);
if (objRef == null)
InstanceObject instObj = objRef.Object() as InstanceObject ;
if(instObj==null)
RhinoObject[] explodedObjects;
ObjectAttributes[] attributesOfExplodedObjects;
Transform[] transformOfExplodedObjects;
instObj.Explode(false, out explodedObjects, out attributesOfExplodedObjects, out transformOfExplodedObjects);
Guid[] IDs = new Guid[explodedObjects.Length];
for (int i = 0; i < explodedObjects.Length; i++)
Guid addedObjectID;
if (explodedObjects[i].ObjectType != ObjectType.InstanceReference)
addedObjectID = doc.Objects.Add(explodedObjects[i].Geometry, explodedObjects[i].Attributes);
else
addedObjectID = doc.Objects.AddInstanceObject(((InstanceObject)explodedObjects[i]).InstanceDefinition.Index, ((InstanceObject)explodedObjects[i]).InstanceXform);
var addedObject = doc.Objects.Find(addedObjectID);
addedObject.Geometry.Transform(transformOfExplodedObjects[i]);
addedObject.CommitChanges();
IDs[i] = addedObjectID;
doc.Views.Redraw();
return Result.Success;
I can provide the files as well…
