Need a script which will label objects in a specific orderobject label example.3dm (230.0 KB)
Select start point
Select direction
Input label description
Input start number
Label points
Select start point
Select direction
Input start number
Label points
Hi Dave,
How were the points created? Was there originally a surface that these points were sampled from?
– Dale
Dale,
Curves were made on the surface
Once curves were made, points were put on surface (divide curve by number of segments)
See attachment for details.
Dave Perry
Critical Launch Manager
Pittsburgh Glass Works
812.868.8260 (office)
812.205.8260 (cell)
206.350.8260 (fax)
dperry@pgwglass.commailto:dperry@ppg.com
IMPORTANT NOTICE: This electronic communication and any attachments may contain confidential information and may be legally privileged. It is intended solely for the addressee(s). Access, disclosure, copying, distribution, or reliance on any of it by anyone else is prohibited and may be a criminal offense. Please delete if obtained or received in error, and email confirmation to the sender.
object label example.3dm (228 KB)
Hi @Dave_Perry,
With the surface, you can make this a 2-D problem rather than a 3-D one.
Calculate the closest point from the surface from each test point. Then sort the test points in what ever order makes sense. Then add the labels at those sorted locations.
Make sense?
– Dale
Can you make a small script and run on this example to show me what you are talking about.
