Hello everybody.
I wonder is there a simple way to change Object ID in a simple way?
Thanks in advance for the response.
Michal
Hello everybody.
Michal
You could copy the object in place and delete the original…
Yeah, that should do the trick, but I thought that there is some special command or something.
Via script it should also be possible - why do you need to do this?
At my work we are using our custom tool for Rhino that creates many file formats using our companys web page, and sometimes we have some difficulties in recognizing correct objects ID after geometry have been altered. That is a short version of how it works :)))
Yes, depending on how the object is “altered”, Rhino will create a new object ID. So during the alteration process, you need to keep track of the ID’s…
Did you get anywhere with this? I have a similar problem. Did the script suggestion make sense?
Did you find a workaround?
What is the specific problem you are having/trying to solve?
I have opened another topic. called…
Plotter - Object Id’s Vector-directions SVG’s
Hopefully it explains my problem Ok?
