How to add a modified object and maintain the same ID? C++
Hello everyone,
I am trying to add to scene of Rhino a modified curve that maintains the same ID from the original one.
I explain the scenario:
The user have to select a set of object, that might be curves, surfaces and points. Then the command will do a set of operation on those object and when the command is finished I add those object on the scene.
I pick the objects by using the CRhinoGetObject class.
After that I retrieve the CRhinoObjRef and then the geometries of the selected objects and cast them to ON_Curve, ON_Surface and ON_Point.
After I have the geometries I modify them.
How can I modify the original objects with the data that I have with the modified object? In clearly, I need that the object that I have selected become the modified one preserving all of its attributes (ID, color, layer, etc. )
They way you do this is:
1.) Get the object
2.) Make a copy of the object
3.) Replace the original object with the modified copy using CRhinoDoc::ReplaceObject
This sample project contains many examples of this.
https://github.com/mcneel/Rhino5Samples_CPP/tree/master/SampleCommands
– Dale
Hi Dale,
How is it possible in vb? i mean replacing object without changing ID.
I tried doc.objects.replace() but id changed.
Thanks
That shouldn’t be happening. Do you have some code that exhibits this behavior?
Yes you are right, now it works. i realized i made a mistake.
Thanks
