Nurbs curve to surface
No one is discouraging me. I just see advices and thank you all for that ! I think grasshopper can make the impossible. Is it possible to make a point a double attractor ? The second attractor could maybe stretch the shape or make it thiner
Ok that really got messy, but I hope you can do something with it. Pls dont look into the file :smiley: The tree Management ****** me up. There is a much simpler way, but at the moment and the 5x5 min, I had time between my work, didn’t let me find a more elegant solution.
If this is still not what you’re after, I can’t help you further.
RadialGritPinch_rere.gh (33.7 KB)
here is a principal sketch how I would do this:
in GH its very difficult, you can however make use of the new fillet functionality or the blend surface command in Rhinocommon (useable by script in GH 1.0+) , its quite challenging though.
Please be Aware, the script is not bulletproof. as soon the regions overlap far each other, you don’t get nice results. I want to replace the “Point in curves” component with something like pull Point, but I don’t know yet, how to seperate the branches for each area.
Tim you are a hero ! Thank you very much this is pretty much the result I expected ! I can’t make your file functional as i’m a newbie with grasshopper but i’m looking into it
out of curiosity, what will that result be?
There is no result only training but i was inspired by this from Mathieu Lehanneur. I can’t really explain how I ended up with this idea.
Thank you for your help Tom !
Well it seems that i can’t make it work. Do i have to set some points or curves ?
Your attractor curves. But this won’t look like your picture. Next time post pls something like that earlier for example as you posted your first sketches.
It’s not what i want to reproduce, it is juste an inspiration to train myself for doing something else
Why not just let the would be surface control points do the work. Similar to how just pulling up controlpoints in rhino would be?
BumpRadialNurbs.gh (9.1 KB)
I would do this as a mesh with a stamp/mask image in Zbrush in like 10 seconds and call it a day. Right tool for the Right job. Keep that in mind.
Tried it with a simple image sampler and a water picture. It’s the first Picture I found on Google, but with the right one, it could look similar to the example.
Thank you mickael, that is much more easier to handle. Is it possible to set different heights ?
Yes just us more movement values in the moves T input.
