I would like to number a list of closed curve (these are pieces that will be laser cut) by adding text inside of them. I already have set up the lists of text but i’m struggling to place them inside the pieces. I tried to evaluate the previous surfaces i made before but the problem is that the text is sometime placed too close of the slits and extends beyond the edge. Is there is some kind of technique to place the text as far as possible from the edges without complexifying the program too much?
Thanks in advance
Waffle Structure Numbering problem.gh (44.2 KB)
Something like this should do it for you.
Hi @Thepogo,
As your geometry is quite consistantly structured you can easily reference to a part of your geometry.
Waffle Structure Numbering problem.gh (43.5 KB)
