Hello guys!
Is there a way to give numbers a format as described in the image?
- Use “.” as thousands separator
- Use “,” as decimal separator
- With two decimals
Thanks
HI Cristian
Is this what you need?
NumberFormat.gh (8.3 KB)
nathanletwory
(Nathan 'jesterKing' Letwory)
3
Except decimal and thousand separator are the wrong way around (:
Thanks man!
it´s almost there. I´m using R5, and it pops up this message:
This is the file of Rhino5
NumberFormat_Rhino5.gh (5.2 KB)
Thank you so, so much!!!
I took it from your file and added a couple things to achieve what i needed. I post it here in case anyone may found it useful:
An observation: the output is no longer a number. It´s a string of characters.
