Number component which calculates angles - default in de grees (instead of angles)
Question;
I have a lot of numerical sums which I would like to have calculated.
The only thing is that the ‘number’ component, takes angels into account, default in radians.
This while all the sums have angle written in degrees.
I know there is a radian component, which converts radians into degrees. However, this is in my case useless because the angles are only a small part of the equations…
Any suggestions of a number components which calculates - default in degrees? (or a work around that all angles are fittet with (rad(angle))?
Here an example of a few equations :slight_smile:
2021-01-25 Calculate with default angles.gh (7.1 KB)
thanks :slight_smile:
2021-01-25 Calculate with default angles_re.gh (12.7 KB)
You might want to add more “Replace text” if you can have uppercase Cos/Sin/Tan situations, or atan/cotan/etc/etc…
Hello
for what is is worth but without any guaranty, a way could be to make an equation parser and say that Trigonometric function needs Degree and not radians. So I tweak a program I did many years ago in c++ then convert it in C#.
Here the results
Ahh thank you, very smart.
That all ( --> (( and )–> )) is very smart. (it sometimes adds and extra (not necessary (( but this does not matter because the number of ( and ) are always equal.
plus with the replace text multiple component of wombat it is possible replace all text items in only 1 component!
Thanks! :slight_smile:
Ahh thank you,
It looks like it is doeing exactly the trick :).
However I also read some uncertainties, And because I am not a C++ expert I can really check it myself unfortunately.
For this reason I used answer of Riccardo to be honest.
But thank you anyways! :slight_smile:
