Inline calculator unit conversion radians to degree
hello everybody
i did not manage to convert radians to degree als inline calculation:
i need to input for example a 10% slope or deviation as angle into the _rotate command.
so i want to calculate 5.71059… degree inline:
_rotate 0 =(degree(atan(0.1))
doesn t work.
how do i convert the atan(0.1) result into degree ?
thanks - best regards
tom
@pascal any idea ?
as far as i understood, atan or arctan is the inverse function of tan
in my initial post i want to calculate an angle in radians using the atan function.
so atan() should return an angle in radians.(0…2Pi)
and the _rotate functions needs an angel in degree (0…360)
(1) i would love to see atan() work
(2) i would understand how to convert the result from radians to degree
To convert from radians to degrees multiply the angle in radians by 180/Pi or 57.295779513082320876798154814105‬.
Rhino command line for arctangent of 0.1 in degrees: (180./Pi*Atan(0.1))
An alternative for the command line is to append “radians” to the result of atan: (atan(0.1))radians. This tells Rotate that the angle is in radians, not degrees. The paranthesis around atan are needed so that “radians” applies to the result of atan.
thanks David.
works
notes:
the old =(…) syntax seams not to work anymore.
somewhere i read, that the Python math Module should be implemented in the Inline Calculator, wich offers a degree() function …
but for me, the question is solved.
Yeah, you can type “180./Pi*Atan(0.1)” directly into the command line.
