Question; I noticed when you insert a formula using sin, cos tan etc, inside a ‘number’ component it automatically calculates the value based on Radians instad of Degrees.
I understand I can deconstruct the formula and manually change into: Tan(rad(15)), see printscreen.
However there is probably a smarter way.
Maybe is there someone able to write a short python code, which automatically changes/calcultes with degrees instead of radians?
Just to make sure: it has to be a generic solution.
2025-02-15 Default Degrees instad of Radians in Number component.gh (5.8 KB)
Many thanks!
