Notilus Scantling for Rhino 8 released
Notilus Software has released Notilus Scantling, a structural rule-check tool for naval architects and shipyards, delivered as a Rhino 8 plugin and a standalone desktop application.
Structural elements are not typed in; they are selected in the model. Position, panel sides, deadrise, plate thickness, and profile dimensions are measured from the Rhino objects, and results are shown back on the geometry. Change the hull, re-read the model, and the check follows the boat.
Key features
  • Elements defined from Rhino geometry, one per selected object
  • Design loads derived automatically from vessel particulars
  • Plates, stiffeners, girders and pillars checked against as-built scantlings
  • Utilization colors and design pressures shown on the model
  • Traceable report with the rule clause behind every requirement
  • Supported rules: DNV-RU-HSLC Pt.3, RINA RES31, ISO 12215-5 (steel, aluminum and FRP) and ISO 11812
  • Works directly with Notilus Composite: laminates and stiffeners are read from the same library, with no re-entry
Notilus Scantling works with Rhino 8 for Windows.
Details and download…
