Notilus HydroStab — hydrostatics, stability and weight in Rhino
Notilus HydroStab is a Rhino plugin for naval architecture: weight from geometry,
hydrostatics, load cases, intact and damage stability, and a stability booklet — all on the
Rhino model you already have, in Rhino 7 and Rhino 8 on Windows.
The panel sits next to the viewport and is organised as tabs: Hydrostatics, Tanks, Loadcases,
Weight Points, Downflooding Points, Margin Line, Damage Stability and Lines Plan.
Weight comes from the geometry
You assign a material or a beam profile to real Rhino objects and the plugin returns mass and
LCG / TCG / VCG per item. Weight points can be linked to the objects they represent, so when
an object moves, the weight point follows it — there is a “Sync Moved Points → Weight” step
that shows you what moved before anything is applied.
The weight report lists every tagged object with its quantity, unit weight, weight and centre
of gravity, and gives the total.
Hydrostatics, tanks and load cases
Tanks are drawn from the model and calibrated by volume, with free surface. Load cases float
automatically — you get draft, trim and heel at equilibrium rather than entering them by hand.
Hydrostatics run for monohulls and catamarans.
Criteria are built in
You tick the standard and the plugin evaluates against it:
  • IMO IS-Code, intact plus weather criterion
  • ISO 12217-1 (motor >=6 m), -2 (sailing) and -3 (small craft <6 m), by design category A-D
  • IMO passenger crowding, A.749 3.1.2.5
Every limit is editable, and there is a reset back to the IMO defaults. The GZ curve comes up
with the criteria table beside it — required value, actual value, pass or fail — and the whole
thing goes out as a booklet PDF with your own company logo, or as a table copy or Excel export.
Damage stability
Lost buoyancy, room by room and tank by tank, with permeability and several damage cases. You
set the load case, heel range and step, and whether the vessel is free to trim, and you can
preview the flooded condition in the viewport. Results come back per condition with heel,
draft, trim, GMt and a pass/fail status.
The short version
Commands
nhsAutoFloat nhsDrawTanks nhsLinkWeightObject nhsUnlinkWeightObject
nhsSelWeightObject nhsShowWeightLinks nhsSyncWeightFromObjects nhsSettings
Notilus Weight — the other half, if you want it
Weight is a separate Windows application, not a Rhino plugin. It is where a weight breakdown
is maintained properly: categories and subcategories, margins, locations, brands, materials,
load cases and centre of gravity, with revisions.
The two products work on their own. If you only need to enter and manage weights, Weight is
enough by itself. If you want the numbers to come out of the Rhino model, HydroStab calculates
them and pushes them across.
The push is not an overwrite. Weight receives it as a new revision and shows you exactly what
HydroStab changed — added, removed and changed items, load cases and compartments, and the
resulting total — and you tick what you want to apply.
The breakdown lives in a shared database, so several people can work on the same project.
Data is scoped per company — you only see your own projects.
Status
Rhino 7 and Rhino 8, Windows, for HydroStab. Weight is a standalone Windows application.
We would be glad to hear which parts of this workflow are the painful ones for you — in
particular which criteria sets you need beyond the ones above, and whether you run damage
stability inside your CAD or outside it.
Download
Notilus HydroStab and Notilus Weight, together with our other Rhino plugins, are available at
Full video: https://www.youtube.com/watch?v=c5Im0L7kWQY
LinkedIn: Notilus Software | LinkedIn
We are glad to run either of them on your own model if you would like to see it working on
real geometry.
