Notilus Composite — composite laminates and stiffeners inside Rhino
Notilus Composite brings composite structure design into Rhino: laminates on your
surfaces, stiffeners with capping and crown laminates, and weight, centre of gravity,
laminate schedule and taping details read straight from the model.
Laminates, layer by layer
Laminates are built from glass, carbon, core and UD plies. Thickness, weight and stiffness
follow the ISO 12215 ply rules, so the figures are the ones you would put into a class
submission, not a rough first guess.
Laminates, materials and stiffener profiles live in libraries, so the same stack is reused
from one project to the next.
Panels and stiffeners on the model
A laminate can be assigned to any surface or polysurface. Stiffeners run from a curve or a
surface, with capping faces and crown laminates. Every definition is stored on the Rhino
object itself — there is no external database to keep in sync, and the data travels with
the 3dm.
Weight and centre of gravity, live
A dockable panel follows your selection and shows the laminate stack, thickness, core, area
and weight of what you picked. The whole model rolls up into a single weight and centre of
gravity, per panel and per stiffener, and it updates the moment geometry or a laminate
changes.
Schedule and taping details
The model is colour-mapped by laminate, with the full schedule beside it — layer by layer,
per zone, with total thickness and weight.
Taping details are generated at panel–stiffener junctions and placed on the 2D sections with
callouts, so the laminate annotation on production drawings is not drawn by hand.
Where it fits
Composite reads Rhino hull surfaces, decks and bulkheads directly. It works alongside our
other plugins: Notilus Steeler for metal structure, Notilus Drafting for production drawings
from the same model, and Notilus Scheduler for planning from Composite’s part breakdown and
weight report.
Status
Rhino 8, Windows. A 15-day evaluation licence is available.
We would like to hear which rule sets you need beyond ISO 12215, and how you produce taping
details today.
Download
Notilus Composite, together with our other Rhino plugins, is available at
LinkedIn: Notilus Software | LinkedIn
