Nothing to undo
sometimes my rhino undo command cannot work and it says in the command bar “nothing to undo”. so i have to close and open back the rhino to have the undo work again. is there any solution for this?
Do you have any information when it‘s happening? Some kind of shematic, or after using a specific command or while using grasshopper?
when i delete an object in rhino and want to undo it then in the command bar says “nothing to undo”.
Maybe run the System Information command from the Help Pull-down menu.
CopyAll and upload it here. Are you running the latest rh6 release?
no im using rh5. and theres no System Information command from the Help Pull-down menu.
No System Info here either, disappeared a while back I think ??
