i keep getting “Nothing to undo.” / can’t undo anything in an important file! it is horrible, im losing valuable information all the time, ay. i keep re launching rhino and sometimes that works but then it keeps happening again. is there a way to fix this?
Is there any operation you can recall doing before you experienced the undo stack loss? I recently reported trying to match hatch properties would do that - there may be others…
i dont know the exact command that led to it. but i did try and match hatch just before and it didnt match properly
Yes, hatch match fails but it also nukes your undo stack - that will happen every time until it is fixed. If you find other ops that do the same, let us know.
so far it seems fixed with the new update. match hatch is working and its not nuking all undos so far
