Not thick according to its shape
Can anyone help me ?
I have a roof but it can’t be thickened to follow a special shape. Then the triangle shape is not perfect, how do you do it?
ROOF.3dm (531.2 KB)
ROOF.gh (16.5 KB)
Hi @Pirman_Nur_Hidayat,
You are extruding your lofted surface in the “Z direction”, you need to thicken it in the direction of the Surface Normals but if you only have 1 surface then you will only get the single Surface Normal from Evaluating said surface.
Here is how you can achieve that with the Evaluate Surface component.
Graph Space:
Model Space:
20240725_ROOF_Response_01a.gh (76.4 KB)
EDIT:
I have a feeling this is what you are actually after?
Graph Space:
Model Space:
20240725_ROOF_Response_01b.gh (84.3 KB)
Hallo @michaelvollrath
Thank you for taking the time to help and support me, I know it’s not easy. I have a question, can the Graphic Room you create be used with other panels such as diamond shapes or others?
.Thank you very much for your attention.
I’m assuming you meant “Grasshopper Script” not Graphic Room?
Yes, the script should work with other panel types… You are using the Lunchbox Plugin for the panel creation, I would try swapping the triangulated panel component with a different panel component and see how it behaves.
Hello @michaelvollrath
I mean, can the script you create be used in other forms of panels? Yes, that’s right, because I use that plugin.
Provided that you give it a single input surface and the referenced curves of that surface as you set up in your original script it should work with different surface shapes yes.
to be honest, I don’t know yet with my own single input surface and reference curve. because it’s all from YouTube tutorials, I’m still new to rhino.
