I’m trying to add thickness to a surface in Grasshopper, but I’ve run into some issues. Currently, I can only achieve this by using the Offset Surface command in Rhino, but this approach doesn’t keep the top surface flat, which is what I need.
I’ve also followed some tutorials that suggest using the Brep Join function, but for some reason, it doesn’t seem to work in my case.
Could anyone guide me on how to properly add thickness to a surface in Grasshopper while ensuring the top surface remains flat? Any advice or alternative methods would be greatly appreciated!
I made some revisions to your Grasshopper file, specifically changing the placement of the point. However, it resulted in this unexpected outcome. I’ve attached the revised file (both rhino and gh) for your reference.
Thank you for your help! Adjustable Holes Grasshopper (1).3dm (2.4 MB) Adjustable Holes Grasshopper (1).gh (14.9 KB)
