I have a developed Rhino plugin that when you launch it from the command line, its WPF UI gets docked as a new tab next to the properties panel. Everything fine so far.
The problem is that when I restart Rhino this plugin is still docked next to the properties panel and I want it just to be loaded from the command line.
That looks like the perfect approach, however the method Rhino.UI.Panels.ClosePanel() doesn’t seem to do anything. The plugin is still there when I restart Rhino and when I debug it step by step I don’t see any changes either.
public class MyRhinocerosPlugIn : Rhino.PlugIns.PlugIn
public MyRhinocerosPlugIn()
Instance = this;
RhinoDoc.CloseDocument += close_plugin;
protected void close_plugin (object sender, DocumentEventArgs e)
// This does nothing
Rhino.UI.Panels.ClosePanel(typeof(MyPanelHost));
// This returns a guid, but it does nothing
var my_guid = typeof(MyPanelHost).GUID;
Rhino.UI.Panels.ClosePanel(my_guid);
// This returns null
var my_panel = Rhino.UI.Panels.GetPanel<MyPanelHost>();
// this returns the guids of the panels, but then all the items of panel_list are null
var guids = Rhino.UI.Panels.GetOpenPanelIds();
var panel_list = new List<object>();
foreach (var guid in guids)
var panel = Rhino.UI.Panels.GetPanel(guid);
panel_list.Add(panel);
// this throws an error, because RhinoDoc.ActiveDoc is null
var my_panel2 = Rhino.UI.Panels.GetPanel<MyPanelHost>(RhinoDoc.ActiveDoc);
I also read that the plugins started from c++ are not accessible through these methods. May it be the case? Although my plugin is a .NET assembly.
