first asked here but reposting for appropriate category
a rhino Plugin containing the following
using System;
using Eto.Forms;
using Rhino.UI;
using Rhino.PlugIns;
using System.Runtime.InteropServices;
namespace SomePlugin
public class MyRHPlugin: Plugin
public MyRHPlugin() { Instance = this; }
public static MyRHPlugin Instance { get; private set; }
public UserPanel MyPanel {get; set;}
[Guid("1234")] // random guid here. no problem
public class UserPanel: Panel
public UserPanel(){ }
public static Guid PID
get { return typeof(UserPanel).GUID; }
and in a separate Grasshopper plugin I have this
// abbreviated code above...
protected override void SolveInstance(IGH_DataAccess DA)
// DA gets all inputs...abbreviated
Guid id = new Guid("9876"); // correct id for the plugin
if (!PlugIn.GetPlugInInfo(id).IsLoaded) { return; }
MyRHPlugin myplugin = PlugIn.Find(id) as MyRHPlugin;
DA.SetData(0, myplugin.MyPanel.ToString()); // this line is where debugger encounters error
when this runs, i encounter a null reference error. it says the getter returns null.
how can i access that panel in my GH plugin? like reading textboxes
I’ve omitted the loading part. that part works. the panel shows correctly in rhino
