Normal map view
Hi, when i modify saturation or multiplication or gain of normal map it disappears in the view and appears just when i move the view
Hi, @Henry_Boutet_de_Monv.
Can you post the result of running Rhino’s SystemInfo command here so we can checkout your system setup, please?
Hi @stevefuchs
Rhino 8 SR12 2024-10-8 (Rhino 8, 8.12.24282.07001, Git hash:master @ 2f42167325d83e0da0f3fe08e796c2b26e602bc5)
License type: Commercial, version 2024-10-08
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.0
Primary display and OpenGL: NVIDIA GeForce GTX 1660 Ti (NVidia) Memory: 6GB, Driver date: 1-18-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.23
Primary OpenGL: NVIDIA GeForce GTX 1660 Ti (NVidia) Memory: 6GB, Driver date: 1-18-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.23
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-18-2024
Driver Version: 31.0.15.5123
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Users\33686\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Fenix\2.0.0.5\FenixToolbar.rhp “FenixToolbar” 2.0.0.5
C:\Users\33686\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\D5Conv (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\0.12.0.0028\Rhino 8\D5Conv.rhp “D5 Sync for Rhino”
C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\TeDAsharp (ce983e9d-72de-4a79-8832-7c374e6e26de)\1.0.8405.22062\TeDaSharp_060.rhp “TeDAsharp” 1.0.8405.22062
C:\Users\33686\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Program Files\Rhino 7\Plug-ins\Karamba\License\Karamba3D_LicensePlugin_Rhino7.rhp “Karamba3DLicense”
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\LadybugTools\1.38.188\Ladybug.RH.Loader.rhp “Ladybug.RH.Loader” 1.38.188.0
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\Pollination\1.48.3\Pollination.RH.Loader.rhp “Pollination.RH.Loader” 1.48.3.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rendu de Rhino” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Ancien rendu de Rhino”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.12.24282.7001
First things first, I’d start by upgrading your graphics card driver which is 9 months out of date. Let’s see if that helps. After looking up your exact card and preferencing the “Studio Driver”, try this: Driver Details | NVIDIA
Ok i make that but it still doesn’t work
.NET 7.0.0
Primary display and OpenGL: NVIDIA GeForce GTX 1660 Ti (NVidia) Memory: 6GB, Driver date: 9-26-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 565.90
Primary OpenGL: NVIDIA GeForce GTX 1660 Ti (NVidia) Memory: 6GB, Driver date: 9-26-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 565.90
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 9-26-2024
Driver Version: 32.0.15.6590
@Henry_Boutet_de_Monv Can you post your file and material(s)? I’d like to test if I can replicate the same behavior with my setup.
test.3dm (1.4 MB)
Briques fines bleues réfléchissantes.rmtl (42.7 KB)
Out of curiosity, does the problem persist if you start Rhino 8 in Safe Mode?
