Why my render display suddenly show very sketchy looking, meanwhile i cannot see the thumbnail for name views, and i cannot print the pdf file either.
Hi -
It’s impossible to tell what’s going on in those pictures.
Please start by running the Rhino SystemInfo
command and copy-paste the result here. We’ll go from there…
Hi, here is the paste:
Rhino 7 SR27 2023-2-1 (Rhino 7, 7.27.23032.13001, Git hash:master @ 4a0030c0d354560df03764f4f49ecc5d119e5118)
License type: Evaluation, build 2023-02-01
License details: Stand-Alone
Expires on: 2023-04-19
Windows 11 (10.0.22000 SR0.0) or greater (Physical RAM: 32Gb)
Primary display and OpenGL: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 12-3-2022 (M-D-Y). OpenGL Ver: 1.1.0
- Windows Main Display attached to adapter port #2
Secondary graphics devices.
NVIDIA RTX A1000 Laptop GPU (NVidia) Memory: 4GB, Driver date: 12-15-2022 (M-D-Y).
> Integrated accelerated graphics device (shares primary device ports)
- This device is not being used
ATTENTION:
No graphics device is being used. Either an error occurred on startup, or certain devices have been disabled.
See below for any possible configuration changes that may help resolve this issue.
- Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 3.3
Anti-alias mode: None
Mip Map Filtering: Linear
Vendor Name: Microsoft Corporation
Render version: 0.0
Shading Language: Not supported
Driver Date: 12-3-2022
Driver Version: 31.0.101.3959
Maximum Texture size: 1024 x 1024
Z-Buffer depth: 32 bits
Total Video Memory: 1 GB
C:\Users\Zhuoying(Joy)Ren\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.22334.1442
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.27.23032.13001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.27.23032.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.27.23032.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.27.23032.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.27.23032.13001
Hi -
Thanks for that.
Rhino is running on software emulation instead of on a / the GPU.
You have a non-hybrid system and it looks like you are running 3 monitors from the Intel Iris Xe device.
Firstly, you need to connect external monitors to the NVIDIA RTX A1000 in your system.
Secondly, we recommend 4 GB of VRAM per monitor that is used. You have 4 GB in that RTX but are using 3 screens.
