parawall9.gh (107.7 KB)
parawall2.3dm (3.3 MB)
is there any other simple way to create this shape_?i wanted this shape should be integrated for any surface.
i guess i cannot modify ground surface openness when i do paneling.i should modify height and ground surface openness
may i look at ur work_?
i don’t understand what you mean by modify ground surface openness when i do paneling
with paneling you will create two grids and control distance between them
patt.3dm (245.6 KB)
patt.gh (7.4 KB)
i need to control Z direction and X directions on both way.for every piece of pattern
as ur solution i just control just Z direction but height is same whole shape.i cannot control x direction.
i try to do this
you control x;y direction by increase/decrease number of grid in u,v direction
changing u v direction make pattern smaller or larger in same way but every pattern should be different.like zaha hadid wall.
thank you i will look
