When I try to do:
import Rhino.RhinoDoc
it works in the python 2 editor, but in the python 3 editor, I got the following error
ModuleNotFoundError: No module named 'Rhino.RhinoDoc'
When I try to do:
Hi Danny,
This looks like a problem with the python 3 editor implementation.
As a workaround you can use the syntax
from Rhino import RhinoDoc
HTH
Jeremy
Thx, it works! Sorry for the late reply.
Hope this get fixed later.
Still not fixed…
RhinoDoc is a class, not a module or namespace. Thus, this is correct:
import Rhino
You can also do what is suggested above:
– Dale
It is extremely confusing that a class lives at the same hierarchy as namespaces and has a similar naming convention.
You’ll get used to it. I’m sure the change between the two Pythons wasn’t without good reason.
