NGonulate crash
NGonulate crashes on a large imported mesh.
No McNeel error report comes up.
I could upload the mesh here, but zipped it is 8MB.
What to do, where to send to?
-C-H-A-R-L-E-S-
Hi Charles - please upload large files here: http://www.rhino3d.com/upload , include ‘Att’n: Pascal’ in the comment, and I’ll get it.
thanks,
Hi Charles - thanks, I got the file - NGonulation worked here - instantly in fact, no crash. I’m not sure what to suggest except, possibly, try again with the (delayed, I know) next WIP. I sent you back a link to the Rhino file.
Do you get the crash on every attempt?
Hi Pascal,
the crash comes up on every attempt and immediately.
I’ll just wait for the next WIP and come back to this then.
Thanks,
-C-H-A-R-L-E-S-
Hello Pascal,
your file is more than the double size than mine.
In the original, it is a very dense mesh, ngonulated it is leightweight.
What is the reason the file becomes so large?
Thanks,
-C-H-A-R-L-E-S-
Hi Charles - good question - NGons do not remove any vertices from the mesh, as far as I know, they only pretend to in order to simplify the display. So, I guess some extra data might be expected from nGons, but it does seem that double is a lot. I’ll see what I can find out.
Hi Pascal,
Interesting.
When the ngonulated mesh gets exploded, then the vertices are all there again.
-C-H-A-R-L-E-S-
Hi Charles - I’ll check with Dale, but my guess of the moment is that NGonulating on this mesh creates a large number of small NGons, not just the obvious ones at the back and the obvious planar parts, and each of these needs to be kept track of - what vertices are in each nGon and so on , adding data to the file - some are just a few vertices, so there are really a lot.
Hi Pascal,
with the new WIP there is no crash anymore.
-C-H-A-R-L-E-S-
