New work _ New Edit
Hi
Rhino7_ Siemens NX
There are weaknesses in the subdivision that I hope will be resolved as soon as possible
can you elaborate on the weaknesses you refer to?
One of its weaknesses is that it puts too much pressure on the system. This is not the case with other software.
And in other software such as adding a few edges in extrusion, etc. in Rhino there are no settings.
https://mcneel.myjetbrains.com/youtrack/issue/RH-57175
https://mcneel.myjetbrains.com/youtrack/issue/RH-56109
https://mcneel.myjetbrains.com/youtrack/issue/RH-54113
https://mcneel.myjetbrains.com/youtrack/issue/RH-52735
https://mcneel.myjetbrains.com/youtrack/issue/RH-54108
https://mcneel.myjetbrains.com/youtrack/issue/RH-58755
what do you mean by "puts too much pressure on the system? "
post your systeminfo please- (run the command in rhino)
Rhino 7 SR0 2020-6-30 (Public Build, 7.0.20182.13135, Git hash:master @ 2ec570915895f774aaba94ea3aadb9f60f8de130)
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
Hybrid graphics system.
Primary display: Intel® HD Graphics 530 (Intel) Memory: 1GB, Driver date: 1-21-2020 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 960M (NVidia) Memory: 4GB, Driver date: 5-15-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 446.14
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-15-2020
Driver Version: 26.21.14.4614
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\XNurbsRhino\XNurbsRhino.rhp “XNurbs”
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7 WIP\Plug-ins\Commands.rhp “Commands” 7.0.20182.13135
C:\Program Files\Rhino 7 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 7 WIP\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.0.20182.13135
C:\Program Files\Rhino 7 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.0.20182.13135
C:\Program Files\Rhino 7 WIP\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
C:\Program Files\Rhino 7 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 7 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.0.20182.13135
C:\Program Files\Rhino 7 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.0.20182.13135
C:\Program Files\Rhino 7 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 7 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 7 WIP\Plug-ins\import_OBJ.rhp “Import_OBJ” 7.0.20182.13135
you have a hybrid system, you need to make sure your nvidia is set to prefer max performance in the power settings. You may also need to disable your intel completely if it is aggressively switching back the intel.
these systems are a PITA to deal with and require some brute forcing to get them to behave correctly with rhino. Since it’s a laptop, the machine wants to send everything it can to the Intel for powersavings, sadly this makes rhino run badly.
Yes, I put it in this mode, it has no effect
Subِd-commands seem to be optimized so that the system speed does not slow down
not sure I’m following you… can you clarify?
