New user, help!
Example-file.gh (30.7 KB)
Hello everyone,
I’m new to using Grasshopper and I’m currently working on an object that I want to increase in size significantly. The problem is that the tool/component used to scale the object isn’t working for me, and I haven’t been able to activate it properly yet.
I would really appreciate it if someone could kindly show me an effective way to scale my object, or give me any tips on how to work with Grasshopper more confidently. I’m still learning the program and getting used to its tools, so any guidance would be very helpful.
Thank you very much in advance for your time and support!
Luckily, you have everything based at 0,0, so the scaling is simple
or there is something in your request I am not getting at all. The script is beyond the simple but the scaling is a basic function.
PS I think I know where the struggle is. If you want to build much larger tower in different magnitude, you need to change the range for each slider, so you do not stick to 10 but 100 or 1000. easier to scale everything at the end.
