New UI - Removing a tool from a toolbar
I’d feel more secure if the delete-undo button wasn’t nested there between these useful undo tools… [unintentional clicks with the Wacom pan are not unheard of]
But I can’t find a way to remove it from the undo toolbar?
thanks a lot
Akash
Hi Akash -
When you press Shift while hovering over a button, the Move | Edit menu pops up. With Move, you can drag the button onto a viewport and you’ll be asked if you want to remove it.
thanks @wim
it worked that way, but It is kind of clanky on the Mac, the pointer does not let you select between the 2 options, after a few tries it did let me delete the button, but it does not behave in a clear repeatable manner.
Akash
Hi Akash -
That seems to work consistently here. There’s some “weirdness” in that the button first gets dragged back unto the toolbar before the dialog pops up, but it gets deleted:
I’m not sure how much of this is the older macOS version that you are running?
