I am finally (with the Coronavirus shutdown) finding the time to play with and test your wonderful product. Could you tell me please if there are any instructions that come with it? For example, how do you determine Tolerance? In the above postings, I noticed a tolerance of 100 and then one of 1000. How do you determine that?
Hi cosmas,
Good question. This tool was made to make terrains where others failed and doing so by checking and sampling all curves. But the sampling might benefit from a better deviation handling. That has no been fully on my radar, so can you supply some example curves with the tolerance issue? It would help me a lot in finetuning the algorithm/logic
Hi holo.
We have been finishing our Project in Suisse Valey.
I have used your script terrain mesh but i found very hard to split mesh parts for final refining and rendering. So my process was to add over Terrain, made with “terrain Mesh” with a drape surface for better splitting and fast work. Honestly i have been testing working with 3ds max and Rhino but need more knowledge to accomplish complex intersections and conforming surfaces, roads and all the master site plane parts in 3DS max.
I have tested “meshsplit” “normal splitting”, meshtrim", "intersections, booleans… Some time it works, some other not.
I send you the terrain parts and some final pictures to your private mail.
Rhino6 is horroble at splitting meshes, but McNeel are working on that for V7, so did you try splitting it there? (There you can try the quad remeshing too)
Oh, not allowed to install on job pc? Maybe you could ask your boss to install it on personal pc? I am sure you would benefit from learning And using sub-d!
Hi guys, I finally found some time to edit and compile a new beta.
This is v.028, nothing changed but updating the exiration date to 2020.10.01 so you have some time to work with it.
On the other hand I am working on a block scatter for this plugin that will let you scatter a block on any mesh, but I have a few questions for that:
It is scattering it evenly but at random point position within it’s grid space.
Do you want it to scatter an empty block with just a point in the insertion point so you can replace or edit those blocks, or do you want it to ask for a block or both? If both then it will make a new block with a point or a line and insert that if no other block is chosen.
Should density be determined by distance between them, or by amount per unit? (I think distance between is easiest to understand)
Do you want both a strikt grid AND random positioning, or just random positioning?
Do you also want random rotation, or fixed rotation (rotation in Z = 0)
This command will be called TerrainScatter and will be included in the next version.
And please report any problems, wishes and needs for the TerrainMesh plugin.
v0.28 can be downloaded here. Just close Rhino and copy this file to the location of your old TerrainMesh.rhp file and replace it.
IF you are a new user then download it to your preferred location and drag that file into Rhino and type TerrainMesh to run the command. TerrainMesh.rhp (21 KB)
Yeah, Rhino Nature is becoming a really smooth tool.
This is just a simple and dumb scatterer that I have had laying around for a long time that I integrate into this tool so it won’t be an advanced, adjustable tool, it’s just to get people started and for me to have my own tool available in a simple matter. That’s why I make this tool anyway
Hi José, I frankly don’t know how to make plugins from python scripts for Mac’s… @stevebaer do you have any simple tools for a simple mind like mine? A similar tool to the sciptcompiler would be great, so I can combine two scripts or more in one plugin.
The new script compiler in V7 should work just fine as it generates a yak package. Upload you compiled yak package and use the package manager on both operating systems to install
No worries, I understand. Whenever you find time to try the new compiler for V7 I will be more than happy to give it a try and post my impressions. Thanks.
