New Plugin: Parametric Blocks
Hi everyone,
Dynamic blocks have been on Rhino wish lists for years, taking inspiration from other software like AutoCAD’s own Dynamic Blocks, Blender’s Geometry Nodes, and others. Recently I built a version of this for Rhino, which I’m publishing today as a plugin named, rather unimaginatively, Parametric Blocks.
A Parametric Block is a normal Rhino Block whose geometry is computed by a Grasshopper definition embedded in the .3dm. Many of the design and data management decisions were inspired by pain points I have faced over the years of using Grasshopper in large-scale architecture projects.
What it does
  • No linked files. The .gh lives inside the .3dm. Copy a block into another file and it stays editable.
  • Real blocks, with reliable fallback. Move, copy, array, mirror, Make2D, render and export them like any block. Someone without the plug-in sees ordinary blocks with the right geometry, and nothing is lost when they save the file.
  • Parameters in the Properties panel, accessible in the Rhino scene, without having to interface with Grasshopper.
  • Double-click to edit input geometry with any Rhino tool, with a live preview.
  • Feels like Rhino’s blocks. I wanted the plugin to feel familiar and intuitive, so it builds its UI largely as an extension of existing Rhino blocks: a manager like Block Manager, an Insert dialog like Insert, etc. Parametric Block commands all start with PB.
Make your own
Any Grasshopper definition can become a Parametric Block Definition by following a simple grouping convention. Put its inputs in a group named PB:IN and its outputs in PB:OUT, then run PBImport; import fills in the required metadata as PB:META (name, id, version, units). For further instructions, see the authoring guide and samples.
Get it
  • The plugin is already available on PackageManager, and has been submitted to Food4Rhino for approval.
  • Rhino 8 for Windows, 8.35 or later. It is available for free, including for commercial work.
Development
While I’ve done my best to test the plugin extensively, I am certain that bugs and edge cases I haven’t anticipated will emerge. I am not an experienced developer. This is version 0.1.1, pretty much a proof of concept, so expect rough edges. I am committed to maintaining the project and adding polish over the coming months, so bug reports & feature requests are very welcome. (the PBInfo command copies diagnostics for the report).
I hope you will find this plugin useful!
Rafael Igayara
