NetworkX/ Grasshopper/ file name or extension is too long error
I’m working on a Python script that uses NetworkX, and I’m encountering an intermittent error:
Error running script: [WinError 206] The filename or extension is too long: 'C:\\Users\\omar\\.rhinocode\\py39-rh8\\site-envs\\default-qVAuLltc\\numpy.libs' [1111:1]
The code works most of the time, but occasionally this error appears. When it does, I have to close Rhino and reopen it for the script to run normally again.
The error is triggered when the code attempts to call the nx.simple_cycles() function.
Can anyone explain why this might be happening and how I can fix it to ensure consistent behavior?
Thanks!
Thank you, James for the answer. I thought that would solve the issue as well but in my case long paths are already enabled in my machine. Could it be related to Rhino itself and long paths not supported?!
The specific path in your error message is only 71 chars long, where as even the default lower limit is ~256
>>> len('C:\\Users\\omar\\.rhinocode\\py39-rh8\\site-envs\\default-qVAuLltc\\numpy.libs')
71
The Windows path length has cropped up in other bugs in Rhino, but this one’s been fixed.
https://mcneel.myjetbrains.com/youtrack/issue/RH-68202
So it’s probably something else, but to rule out the path length, try creating a file at a long path with:
with open('C:\\Users\\omar\\delete_me' + '_'*300 + '.txt', 'wt') as f:
    f.write('Hello world')
LongPathTool resolves issues caused by intermittent WinError 206 even when paths appear short due to environment quirks
