Grasshopper script crash using network library
Hi all,
I am using “nc library” in python (Visual studio) to receive some data over network and it works properly:
However, I can’t read data from “Script” in grasshopper as it crashes:
And it’s not just about nc lib. I have used other libraries and same result.
Is there any problem within the grasshopper python as it is using iron python not the python, or am I doing something wrong?
Cheers!
Farzad
[edit] sorry! I didn’t notice you were using Python 3 component.
Can you connect a text panel to out, and post the error information?
Does it throw an error or just gets stuck? Does the same script work from outside of rhino (run it in a separate python instance)?
It gets stuck. I receive no error.
Yes. the same script works outside of Rhino. I used visual studio code.(see screenshot attached above).
I can send the script if you want.
