Hey there. Can anybody tel me how to make a surface in GH with these curves? can not make it work… maybe I need an other solution?!!
14|690x357
A2.3dm (288.6 KB)
A2.gh (22.5 KB)
14|690x357
A2.3dm (288.6 KB)
A2.gh (22.5 KB)
ah, ok!
Thanks a lot !!!
and which command is the first one? I don´t know that one…
It’s the “merge” component. It allows you to merge data in a quite readable way.
You could also use the shift key when connecting each of your curves to the “curves” input of the patch component. Your choice…
thanks a lot !!!
A2.3dm (453.2 KB)
A2.3test.gh (46.6 KB)
sorry to bother again but I got stucked again… do you maybe know how I programm to change the two red points to the distance of the green ones in order how close the component is to the attractor (1) ??? (pic)
