Network Surface Producing A Null Result
I’m trying to build this element into a single surface in order to create a façade. However, I’m having a issue where the output from the Network Surface surface component is null. I’ve check the data trees through the script and everything seem to be constant/matching.
Gh Script: Facade_Diamond_help.gh (15.0 KB)
@adam_murray272
Maybe you could loft your joined curves? It gave me a pretty good result. Not sure if that is what you are looking for. :slightly_smiling_face:
Just ignore the other curves.
Also you have duplicate curves in the merged set of curves.
Hey Ryan,
I appreciate the suggestion, but the problem with that solution is, I need the entire element to be one single surface and not a brep which is why I’m trying to use the network surface component. I plan to unroll the surface and test façade options on it after.
two curves (in red) were repeated two times:
and sorting the curves helped :slight_smile:
Facade_Diamond_help (1)_Re.gh (24.3 KB)
Hey Inno,
Thank you so much for the solution, it’s been very helpful!
