Hi everyone,
I’m trying to build a surface between curve A, B, C and D. (Please see in the screenshot and the gh file attached)
I first tried Sweep2 but the surface quality is not ideal. Thinking in Rhino when sweeping I can add slash, I tried using Tween Curves in Pufferfish to build the slashes and did network surface, got the same result. I then added another curve from those slashes’ mid point, thing’s improved but still not ideal.
I realised that the planes of curve C and D are actually perpendicular to B. So I tried sweep 2 in Rhino and adding slashes that were also perpendicular to B, got the perfect result. How can I achieve the same thing in Grasshopper??
Any help is appreciated! Thank you in advance!
question.gh (16.6 KB)
