.NET Framework vs .NET Core (K3d, Rhino 8, Rhino.Inside Revit)
I currently have 2 main workflows with Karamba3d:
  1. Use Karamba3d with Rhino/Grasshopper.
  2. Use Karamba3d with Rhino.Inside Revit/Grasshopper.
To use Karamba3d in RiR (Rhino 8), I understand that I need to have the .NET Framework version installed.
However, when I am not using RiR, do I still need to use the .NET Framework edition?
i.e. If I want to use RiR with Rhino 8, do I need to always run Rhino on the .NET Framework regardless of if I am in Revit or not?
Hi Dan,
You can only install one instance of Karamba for RH8 installed at one time, so if you need to run RIR, then I suggest you keep the Framework installed all the time.
best,
Matthew
