Karamba3d installed via PackageManager not working in .NET Framework
It seems Karamba3D (3.1.40918) installed via PackageManager in Rhino 8 (SR10, 11 and 12) only works when Rhino is running in .NET Core but not in the Framework. Is this intentional?
@cp1 @matttam ?
I believe this should be possible by following the procedure introduced in Rhino 8.2 (?).
ShapeDiver plugin seems to work in that way.
yes, only core is available via package manager.
Ok, thanks for the verification. Could you find it in your hearts to deliver both using the multi-target approach mentioned in the earlier link? That would be awesome.
Hi @tuomas.lehtonen,
thank you very much for the above link!
I will try to use that for future releases of Karamba3D.
ā€“ Clemens
