Hello everyone …
is there any Rhino developers here ?
we - right to left languages users - are really suffering from an issue that needs to be solved
I personally depend heavily on shortcuts … and I use Rhino simultaneously with the communication apps ( chats and social media) that I use Arabic in … when I get back to Rhino I need every time to press Alt+Shift to get back to English … and since I swap alot backth and forth between communication and modeling I don’t always remember to change the language … so I find myself writing commands and shortcuts in Rhino in Arabic for no use !!!
to mitigate the irritation I started to write two aliases for each command : one in Arabic and one in English … so I need to make two shortcuts for each command and that’s a hell of a work if you have over hundreds commands and aliases !!!
can anyone find a way to make the command line uni-lingual ???
this would solve the problem permanently … and thank you so much in advance
