Need to create custom attribute text for point coordinates for curve
Hello team,
Currently i am seeing to display the value for point coordinates for points only. But in my case i have a curve which has both ends (start and end) coordinates value (x,y and z) value need to be displayed as a attributes in the attribute section. So that i export the coordinates values for each curves.
Note: I can see the values of start and end point in the properties > more detail > geometry section.
We can see start and end point coordinates value.
curve
Object name: (not named)
Layer name: DXF-Layers::Ground::ZoneA-RoadNew1
Render Material:
source = from layer
index = -1
Attribute UserData:
UserData ID: CE28DE29-F4C5-4faa-A50A-C3A6849B6329
Plug-in: 17b3ecda-17ba-4e45-9e67-a2b8d9be520d
description: User text (2 entries)
saved in file: yes
copy count: 10
Geometry:
Valid curve.
Line
start = (777.534,802.991,0.000)
end = (777.837,803.150,0.000)
domain = 0.000 to 1.000
line length = 0.342
