Is it possible to export the points from a curve? each point should have the X,Y,Z properties. We are talking about contour lines. Thank you very much.
Greetings
Boris
Greetings
Boris
Hi Boris -
You could use a macro for this:
All ExtractPt -Export A:\test.txt enterend Delete
(I have an "A:" disk on this machine - you’ll need to provide a path that you can write to without requiring elevated permissions)
Thank you for your help. I do not know anything about macros. I have inserted it like this. But it does not work.
Gruss
Boris
Hi Boris -
That’s what I meant with using a path that doesn’t require elevated rights. Typically, creating files in the root folder on C:\ requires special permissions.
Try using C:\Users\<your user name>\Desktop\test.txt
(put in your real user name instead of <your user name>
I have taken the easy way
Line Activated - ExtractPt - done
Thanks for your help with the command
Greetings
Boris
Here is a quickie Python script which will export selected curve control points in either .csv (comma delimited) or .txt (space-delimited) formats. Beware, it adds a blank line between each curve’s control point set to make reading easier.
ExportCrvsCtrlPtsSimple.py (1.2 KB)
Is it possible to omit the blank line?
Yep…
ExportCrvsCtrlPtsSimple2.py (1.2 KB)
Perfect! Thank you very much.
Greetings
Boris
