Block Coordinates Attributes and Import excel data
Good Morning Everybody,
for my first post on this forum, I have a tricky question I think about attribut and export/import on excel.
First of all, I need to add an attributs with le “z” coordonate of the block but the only option I found is to create a “point” inside my block and select it and use the fonction “%<PointCoordinate(“162ed99f-79e7-476d-aee6-3c56f81ece57”,“Z”)>%” but in this case, if I copy/paste this block, I need to reselect the point of the new created block because the attribut fonction still link to the previous “point”.
So my question is : Can I just link the coordonates of the block and not from one random point ?
My another question is about import excel datasheet with attribut. In my case, I would like to export all my attributs data in excel to fill some info and after import the data in rhino. (in the same way of Autocad if you know)
I only found on internet how to import by pdf file but it is not dynamic, it is like importing a picture…
Thank you all for your help
Kind Regards
(I am working on Rhino 8 and windows 10)
