I am using the OpenNest command version 1.5.1 on Mac
I have placed all the points correctly, but in the output I get an error.
grasshopper solution exception failed to load file or assembly ‘OpenNestLib, Version=1.0.0.0, Culture=Neutral, PublicKeyToken=nuff’. A specific file could not be found or loaded (x80131621).
How can I fix the problem?
OpenNest is only compatible with Intel processors. Fortunately, you can get Rhino to run in Intel mode even on Apple Silicon. See here for details: OpenNest not working on Rhino8 + Macbook M2 Pro - #12 by curtisw
Hope this helps!
Curtis.
Thank you very much, if it could be solved. I just use a M1 chip.
Hey @Eduardo_David_Román,
It can be solved, you must run Rhino using Rosetta (x64 mode). Right click on Rhino, select Get Info. Then, check “Open using Rosetta”.
There’s no way, other than the others of the OpenNest plugin, for it to work when Rhino is running in native Apple Silicon (arm64) mode.
Does this issue exist with Rhino 8 and OpenNest 2?
I compiled it to work for any mac processor both arm and intel.
