Hello, I am doing some experiments with a ceramic 3d printer and I wanted to create a vase mimicing the pattern of a drop in water, luckily I found a tutorial https://youtu.be/MzDwjAEmavU?si=cCtKQRByhHe6dDQD the problem is, i want to do it all on grasshopper but don’yt know how.
From what I’ve tried my main issue is the points not moving parallel to the normals(?).
I’ve also tried something to the tutorial and afterwards getting the pattern on the cylinder surface but was unable to…
have a look at this core function, it should get you somewhere.
(just don’t put your influence points right on the surface you are dividing to get the point grid, there needs to be a little distance for falloff function to work well)
lofting periodic curves is preferable to srf from pts.
