Need help to this script c# shell and offset mesh(solid)
need help to this script c# shell and offset mesh(solid)
have error
shell mesh offset solid inC#.gh (11.0 KB)
Have a look at the attached:
shell mesh offset solid inC#.gh (17.3 KB)
Also, to debug you c# components, plug a Panel into the out output of the component to read and fix your errors
thanks ,nice:… have you suggestion tutorial for c# video link?
:pray:
Actually yes!
This is by far the best one around:
thanks again
Sorry i have another problem with (point2d) please help me
in :https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_Surface_Evaluate.htm
707
uv point.gh (15.0 KB)
Your surface was unsuited for Softediting, it would not have worked in native Rhino, too.
To be able to soft edit a surface it needs some amount of control points to actually move, your surface only had 4 cps defining it edges. I put in a C# script to rebuild your surface and fixed your error when converting from an MD-Slider to a Point2d in surface parameter space
uv point.gh (18.2 KB)
i have problem in “Curve.CreateBooleanRegions” in new update rhino wip7 c#
please help me …
https://mcneel.myjetbrains.com/youtrack/issue/RH-54846
Curve.CreateBooleanRegions.gh (7.2 KB)
@dale
@lando.schumpich
you missed the out argument in your function call.
https://www.dotnetperls.com/out
ok but i have problem to convert 'Rhino.Geometry.CurveBooleanRegions to Curve
rhino Rhino 7 SR0 2019-10-9 (Public Build, 7.0.19282.09515
“”“” Error (CS0029): Cannot implicitly convert type ‘Rhino.Geometry.CurveBooleanRegions’ to ‘Rhino.Geometry.Curve’ (line 57)“”
Curve.CreateBooleanRegions.222gh.gh (10.9 KB)
@dale
@lando.schumpich
@DavidRutten
still missing the out argument of type CurveRegion
read up on how the “out” keyword works in c# https://www.dotnetperls.com/out
try
Curve[] k = Curve.CreateBooleanRegions(new[]{curves}, plane, combineRegions, tolerance, out CurveRegion[] regions);
or
c = Curve.CreateBooleanRegions(new[]{curves}, plane, combineRegions, tolerance, out CurveRegion[] regions);
for shorter code
Hi @architect.civil5
quote=“architect.civil5, post:12, topic:87635”]
[/quote]
Have a look at this link - you’ll see that the API has changed.
– Dale
I was not successful!
Curve.CreateBooleanRegions.333gh.gh (13.2 KB)
Thanks ,yes API changed but cannot work for me
Curve.CreateBooleanRegions555gh (1).gh (8.6 KB)
Hi @architect.civil5,
See the attached.
CreateBooleanRegions-FIXED.gh (8.9 KB)
– Dale
Thank you for your reply ,it is very Useful code
Is it possible to add created.curve.region to the new rhino6{c#} update as it is very useful؟
Sorry, no. This API is new to the Rhino 7 WIP.
– Dale
Hello friends, why do you think this code does not run?
var d = MeshingParameters(density);
    mesh = Mesh.CreateFromBrep(Brep, d);
    mesh = Mesh.CreateFromBrep(Brep, MeshingParameters(density, minimumEdgeLength
mesh = Mesh.CreateFromBrep(Brep, meshingParametrs);.gh (10.9 KB)
