Hi guys,
In Rhino in the command line I can invoke commands like SelBoundary and CurveBoolean
There are similar methods in C# without using RunScript?
tks.
Hi guys,
tks.
Hi @0904,
The Rhino SDK does not have functional equivalents to Rhino commands. That is, if you don’t want to script a Rhino command, you’ll need to write your own version of the command.
– Dale
Hi @dale
I understand the meaning, but it is not clear to me:
in practice I should use combinations of the various methods present in C# to obtain the same result as the command in Rhino. . .
Is even a minimal code example possible or could you point me to a link?
Hi @0904,
Yes correct.
For SelBoundary, you might start with ObjectTable.FindByWindowRegion. I don’t have a sample that uses this. But the parameters’ are pretty simple.
For CurveBoolean, use Curve.CreateBooleanRegions. I do have a sample of this:
SampleCsCreateBooleanRegions.cs
All of the RhinoCommon samples can be found on GitHub.
GitHub - mcneel/rhino-developer-samples: Rhino and Grasshopper developer sample code
– Dale
ok @dale thanks for reply ![]()
ps therefore even if there are no dedicated functions, equivalent to the commands in Rhino, with C# by combining various methods it is possible to replicate (almost all) the commands typed in the Rhino toolbar.
