I have made this script which will be part of a roof structure system
Test Curve.gh (13.2 KB)
. I want to add the lines to my current model but as the whole structure is on a grid system the rafters/Lines I need to add is 7500mm away from the origin point. but since the top line is inclined I am confuse about how to go around solving the problem. Can you please help me with it?
English is not my first language so please forgive any mistakes
Assigned to Grasshopper category
I have a unit problem with your file, but the idea should work the same.
Basically the idea relies on Divide Length
and then intersect the inclined curves with a perpendicular frame.
And if you need 7500 along each curve, then Divide Length
alone is enough.
Test Curve.gh (18.1 KB)
Thank you so much. I dont understand the blocks yet but it works and I will try to learn what each of them does. You guys are wizards
