Native - Grasshopper - API relation
Personally I would stop all the development to clean up the mess that exists in the relation among native commands - grasshopper components - api available calls.
This is a continuation of a logical demand that I have for years.
the native-grasshopper components-api all of them should be synced and you have to be able to do the same thing with each method.
Let me be more specific by giving to you an example per relation.
  1. Native command - Grasshopper components: Wall from UI has numerous options, like cleanup radius, maximum extension and bottom-top offsets byobject. Grasshopper wall component has only style, alignment, alignment offset and height. Why? This example is not a crucial one. In the past had found a very big limitation, but I cannot remember which one. But it does not matter. No matter what, the have to provide the same options and abilities. We need grasshopper to parametrize our workflows not to limit our options. Selecting between native commands and grasshopper approach should not be affected from the limitations, limitations should not exist.
  2. Native command - API call: You can enable and disable guides from the UI panel, right? You cannot enable and disable guides from API call. This affects a pluging that I’ve developed and presented to you in the past. You mentioned that it would be easy for you to provide access to an API call, months have passed now, and the API call is not available.
  3. Grasshopper - API calls: I cannot think of an exact case scenario, but you get the point from the above. One thing that I discovered while building a plugin involving AI assistance is that combining API calls with grasshopper .ghclusters, can provide powerfull scripting abilities
I tried to explain the above with examples, but the approach should not be: let’s fix this example or that, but clean the situation and have the exact same micro-settings and capabilities among the whole system.
Lastly, an strong API documentation is a crucial high priority task TODO in my opinion.
