Ant: Your AI copilot for Grasshopper - New plugin on food4Rhibo
Ant is a new AI plugin that builds, modifies, and explains Grasshopper definitions for you, directly inside the interface.
Unlike generic AI chat tools, Ant can “see” what you are working on. You select a part of your definition (or the whole thing), open the command panel, and tell Ant what to do.
It translates the actual logic of your components and wires into a structured format that the Large Language Model (LLM) can understand. The AI analyzes this data and sends back precise instructions, which Ant executes directly in your Grasshopper canvas.
Here is exactly how Ant helps you:
  • Turn text into nodes: Type “Create a Voronoi pattern on this surface,” and Ant will place and connect the components for you.
  • Write code instantly: Need a complex loop? Tell Ant to “Write a C# script to randomize these panels,” and it will generate the code inside a script component.
  • Understand definitions: Select a messy cluster of components and ask, “How does this logic work?” to get a clear explanation.
Start designing and let Ant do the heavy lifting!
Details and download…
Posted Feb 13, 2026 by Cécile Lamborot on Rhino News, etc.
