Ant AI is a context-aware AI assistant that lives directly on your Grasshopper canvas.
Unlike standard chatbots, Ant “sees” your work. By selecting components as context, you can interact with an LLM that understands your specific data structures, component connections, and design intent without ever leaving the Rhino/Grasshopper environment.
Born from a concept at the AEC Tech Hackathon in London, Ant has evolved into a professional-grade tool that removes the friction between a designer’s idea and a functional parametric definition.
Transform your workflow with three powerful modes
Ant features a seamless chat interface with three primary modes and specialized commands to handle the “heavy lifting” of computational design:
Ask Mode:
Understand Logic: Inherited a complex script? Select a group of components and get an instant algorithmic breakdown.
Debug and Plan: Ask for advice on how to solve a geometric problem or find out why a specific definition isn’t working.
Explain: Receive a step-by-step logic overview of any selected part of your definition.
Edit Mode:
Natural Language Building: Use simple text prompts to generate native Grasshopper components and wire them together automatically.
Modify on the Fly: Tell Ant to “add a slider to control the radius” or “divide this surface into panels,” and watch the definition update instantly.
Script Mode:
Zero-Friction Coding: Generate Python or C# code directly within script components.
Auto-Context: Ant automatically reads your component’s input names, data types, and structures (Item vs. List Access). You no longer need to spend 10 minutes explaining your data tree to a separate chatbot.
Instant Execution: Write the prompt, and Ant injects the compiled code directly into the editor.
Key features:
Context-Awareness: Select any part of your canvas to provide the AI with the specific context it needs for accurate responses.
Integrated UI: A modern, dockable chat window that supports both Light and Dark modes.
Native Output: Generates real Grasshopper components and wires, not just text-based instructions.
Multi-Language Scripting: Full support for C# and Python.
Iterative Design: Use the chat history to refine and evolve your definitions through conversation.
Download ANT AI from food4Rhino…
Posted Apr 30, 2026 by Carlos Perez on Rhino News, etc.
